busybrit
Came across a situation today that I'd like an opinion on.
The MGB I was working on starts ok but there is a slight noise "most, but not all" of the time you try and start it, it sounds as if the starter is having a very slight difficulty trying to mesh straight away with the ring gear. It always starts with out an issue. When I momentarily supply direct power to the lead going to the solenoid from the battery terminal on the starter, or from any other live point say the fuse box, the starter engages straight away and there is no grind, "if you could call it that", or hesitation.
The starter is new as is the starter relay.
So, for now it's on a push starter button with out any issues. Any ideas as what could be causing this???
Thx
Thx
