Rut
I have a mixture of transmissions and engines for my BE and I've looked over the spare rib case unit, cleaned it up and flushed it out. Everything looks new inside the case, but what do I know. The synchronizers have nice pointy ends, gears show no wear, it shifts nicely and came off of a '72. There was a little, possibly a lot of metal in the case that flushed out, some copper or brass and some aluminum bits, very fine. That being said, I want to get a slave cylinder to go on it to mount to a 1275. I'm using Tilton 3/4" masters, what slave cylinder should I use? Also, can you mount the slave cylinder prior to installing the engine/trans unit? I plan on adding a remote bleed set-up to the slave.
Thanks, Rut
Thanks, Rut
Hi Guest!
