I would change most of those things and more on any car that has been off the road for a long time, especially one that has an unknown history.
As a minimum, change the oil and antifreeze. Replace the spark plugs, plug wires, cap rotor, and probably the points and condenser. Replace all the flexible rubber lines on the fuel and braking systems. You must flush out all the old brake fluid and replace with new. Anticipate rebuilding or replacing the brake master cylinder. Replace the radiator and heater hoses. The carb diaphragm is probably stiff from age and probably would need replacing. The carb(s) themselves would certainly benefit from dropping the float bowl and hosing the bowls and jet tubes and needle with carb cleaner. You may find you need to drain the fuel tank and flush it out as well. When putting the fuel system back together, place a large, disposable, transparent/translucent fuel filter right before the carb(s) to catch all the debris that will become loose in the tank.
Waking a long dormant car and having it returned to daily use involves replacing a lot of parts and performing many steps. When you are done you will have the satisfaction of having done most of this yourself (unless you have deep pockets). Even if the car looks aged and worn this will give you a lot of pride in your car, something you won't have with a typical daily driver.
