Where in philly do you live? I live Nort/Northwest about 40 miles in chester county. I can tell you for a fact that the MGB will fail emissions if you do not have a cat on it and a stock intake. (although some shops may not know the difference between the stock ZS and a dual SU setup). However, it will fail if they obey the letter of the law. My brother's MGB does not pass and is driven less than 5000 miles a year (at least that's what the odometer says ... we haven't done anything to it yet, but will if we must). It's a 1980, so it doesn't qualify for antique until next year. It had to pass originally to be registered in our name, but will no longer have to pass. However, it didn't pass on its own and required extensive fiddling. If you are going to make mods, you need to retain a cat, and wait until you register it (and inspect it for the first time) before making major changes to the intake. Once its been registered, you can probably get away with changing the intake, but will never be able to pass, regardless of mileage, without a cat because it will fail on sight.
Oh, about the above, 5000 miles is the necessary mileage exemption, which is why we limit the mileage on the MGB to that number. That just means it only has to pass visual inspection, not the running emissions test.
Ok, on to the subject of antiques (like my midget). Mine is pre-cat, however, if it was catalytic converted originally, it would never need to pass because it is registered as an antique. In PA, classic cars are emissions exempt (15 years) and antiques are emissions and inspection exempt (25 years old). However, this does curtail your driving abilities. If its only a fun car, register it as an antique and have fun. If you plan on driving it more than 3X per week, you really couldn't get away with antique registration.
I spent the past summer working for my mechanic, so I learned considerable information on PA state inspection above and beyond that which I learned in order to register my antique. Some emissions shops are stricter than others, and some won't even know the difference between a SU and ZS carb setup. I'm sure that you can get someone to pass it, cat or not, but of course, it isn't technically legal without a cat or the original carbs.
[ 04-14-2004: Message edited by: Matthew E. Herd ]</p>
