Alan_Myers
Hi all,
I unpacked a new set of rotors for my TR4, installed them and noticed one in particular appeared to have a lot of runout. Checked it with a dial gauge and found .012-.013 approx. The other wasn't visually obvious but tested to also have about .008 runout.
Since the service manual said .002 maximum allowable, off I went to a local shop that turns rotors to have them trued up. Paid my $30 and waited overnight. Fitting them up today, I thought I could still see some wobble in the worst one. Once the pads went in, I could hear it dragging, too. So I again attached the dial gauge and found the two rotors measure .010 and .007 runout, respectively. The local shop didn't seem to do very much with them!
Do you think I should take them back and ask that they try again?
Can anyone suggest anything else that might be causing the runout? The rotors were turned while fully installed on the hubs, of course, with brand new bearing races installed. Matching, new bearings went back in today. The axles are old, but appear to be in fine shape. I checked, checked and triple checked bearing adjustment. Both wheels are currently spinning smoothly with no hint of play. The rest of the suspension is all newly rebuilt, but unlikely to have any effect on the rotors, anyway.
In fact, I'm not sure any of these other things could cause the rotors to appear out of true. Or, if .010 and .007 are really enough to worry about. Perhaps when the new brake pads bed in they will cure some of it, anyway. (I've got semi-metallic on the car right now, but will be changing to Kevlar pads when they arrive.)
What do you think?
Thanks in advance!
Alan
What do you think?
Thanks in advance!
Alan
