Bruce_B
Almost done with putting together my 1275 engine. Only thing left to do is check valve/piston clearance and valve spring binding.
Part of me says to just go ahead and put on the cylinder head and keep going. Other part of me says that after all I've done, don't take shortcuts now.
I just need some encouragement to do the right thing, unless there's an opinion that the tests I mentioned really aren't needed. I've put together other engines without knowing about these tests and they worked fine.
