Bret
Things to do in 2004 (& 05).
Here are some of the more pricey things that are either in the works or I am planning on addressing before years end as part of my long term plans.
First of on tap is to redo my 78Bs suspension. The parts are already on order! I am chucking the tired old leaf-springs & lowering blocks in favor of some new lowering (~1”) springs. Second, while I’m under there I’ll be replacing all of the bushings (front & rear) with the polyurethane ones made by Energy.
Breaks are next. Up-rated pads & shoes and stainless steel brake lines. Possibly vented & cross drilled Rotors.
Wish list: I plan on making a final decision on what I want to do with the engine & transmission. The question is do I go with a V6 engine swap or stay with the 1.8L.
If I stay with the 1800cc I’ll want to take my time and do it right. So I’ll be looking to locate another “used” engine (short or long) block to rebuild. This will also allow me continue to enjoy my car while the work is being done. I am possibly considering going +20 or +30 over. Go with a fast street or road cam, double timing chain, up-rated oil pump and generally beef up the lower end wherever possible. For the top end – I’ll probably go with either Aluminum or a European spec head (ported & polished?) and maybe go with some roller rockers too.
As for breathing: I think it’d be smart to wait for a final decision on this until after I finish with the major engine work above. But while I really like the new Supercharger offered by Moss, I think for my money I would be better off with duel SUs, a downdraft Weber or maybe consider a side draft DCOE Weber.
Electrical & fuel delivery upgrades: Depending on some of my upgrades I will more than likely have to upgrade my Distributor and go with a solid state fuel pump.
Transmission? This too will probably wait until the engine is done. But I’d like to go with a solid 5-speed with an up-rated heavy duty clutch.
Granted some of these options implementation will have to wait until my 78B is exempt from emissions testing once & for all. Or I might start looking for an earlier car that is already exempt.
