coldplugs
rick_ingram said:Only the office and small work shoppe area (totalling 24'x48') is heated...yes, with propane.
I've got a couple of smaller propane heaters, and will be buying a salamander later this fall. Open to thoughts on radiant heatint options.
I heat my place, which is about the size of your "small" shop area, with a single Modine hot water unit but if I had it to do over, I'd use radiant with those plastic pipes embedded in the floor. Too late now, though.
