In the middle of a suspension rebuild. Discovered a shim under the front mounting bolts of the front right shock. Would this be something that could have been done at the factory to fine-tune the caster? Or is this a previous owners attempt at a tweak?
I preface this by saying that I am assuming that shimming the front or back of the shock would have an impact on caster. If I'm incorrect then I'm sure I'll here so pretty fast. Be gentle.
We were thinking it may be factory. The car went through a mild resto 15 years ago (a 1960 MKI BN7). At that time we know the suspension on that side had been swung out of the way to clean up the frame. Because the caster has always been out by a degree the wrong way on that side, we think that the PO inadvertantly put the shim under the front of the shock, instead of the back, where we think it originally belonged (to get the caster right).
What do you all think?
