Rob_P
OK, so being a newbie i am trying to wait until my manuals arrive before i start breaking stuff. That approach doesn't seem to be working.
I could not get the car into 3rd gear, 1,2,4 and R were not having a problem.
Also, the shifter was hard to manage, felt sloppy and not very cooperative.
I read the previous post started by paul "THe 70 won't go in Fourth Gear' and i was waiting for my manuals to arrive before checking the selector forks.
In preperation, i removed the shift lever, what i noticed was the cover that holds the lever down seemed to be what was keeping the tranny from getting to 3rd. I was able to reach third with the cover off (while doing my best to keep the lever down)
Also, the lever was moving fairly easily.
So i spun the cover 120 degrees and re bolted it down, here is my question. everything works fine if I do NOT tighten the cover down all the way, too tight and it will hold the ball from turning, i loosened it and the tranny shifts like a dream, well, not quite a dream, but much better then before.
How tight is that cover supposed to be?
Is this normal? or is my shifter lever not low enough?
Thanks,
Rob
Thanks,
Rob
