wkilleffer
Hello,
In the last few days, we've had some hot, humid weather, and my 74 MGB's temp gauge is reading just on the other side of the N. You can see the whole letter when driving 55-65 mph, and the top of the right side of the N is covered when driving slower. I'm using a 190deg thermostat.
I'm trying to get the car to run cooler and better. This has involved valve clearance and carb adjustments, and now ignition check up. Probably should have saved the carbs for last. I changed and set the points gap and spark plug gap, and decided to check the timing.
In the Haynes book, an 18GK engine is supposed to be at 10deg BTC at 600 rpm, which looks like the third tooth on the engine timing mark. With the vac advance disconnected and the manifold tap plugged, the engine was running at roughly 600 rpm. The timing mark was down between the first and second tooth. So, I turned the dizzy to move the groove up even with the third tooth, and the idle slowed down. I adjusted it up, and the timing looked to be in the same place.
After putting everything back to rights and reconnecting the vac advance, it looked like the timing mark dropped down to between the first and second tooth, and a throttle rev sends it up to maybe around the fourth tooth.
So, I guess my questions are did I do this right, and could the possibly overadvanced state of the engine be responsible for the engine's temp seeming a bit high?
Any advice and suggestions would be appreciated.
Thank you,
Thank you,
