Service Bulletin needed
Celtic2
Member
I am in need of the complete service bulletin T-62-10 (Western Zone). Does anyone have a copy they will share?
gary
Thanks, but that's not it. The one you supplied is from the Northeastern Zone and quite often the numbering is different than the Western Zone. The one I am seeking is regarding the radio mounting bracket. I have the drawing but not the text portion of the service bulletin.
BTW- I appreciate the one you supplied as my copy was rather poor.
gary
Gary, I don't have a copy of that bulletin, but I have these drawings that may help. Did you try Teri Anne Wakeman's site?
Sorry, I don't have it. I knew the numbering was sometimes different, but sometimes it is the same ... oh well.
Randall-
You happen to have any more of those 62 bulletins sitting around? There's a gap in Teri Ann's and others archives and 62 is one of those missing years.
Randy
Thanks you Randall and Frank.
As I had mentioned, I have a drawing from the bulletin. It appears it may be a supplemental drawing issued after the original was issued. It shows the early TR4 bracket (drawing that Frank attached above) and how to attach the bracket and radio. The title of the drawing is "Special Instructions for Use of Wrinkle Finish Radio Mounting Bracket". "Wrinkle Finish" is double underlined, placing the emphasis on those words. I would like to see if the bulletin mentions the other radio bracket or has a drawing of it.
My goals are to find the correct original bracket for my early TR4 with the vinyl covered lower support bracket, and in the process, possibly clear up some of the confusion on the many versions of these two brackets.
gary
Yeah, there are some more 62 bulletins in the pile. Not sure how many, but I saw at least 4 or 5 before I found 62-10.
One of these days I'll work up the nerve to ask if I can use the big scanner at work (with the automatic page feeder) and run the whole pile through it, along with the factory cross reference listing and some other odds and ends. But there has been a lot of turnover lately, most of my friends are gone and so it doesn't seem quite the right time just now. And there are just too many to run them all through my home scanner.
