sensor??????
61601
hi everyone,i have 2000,xj8 i have a problem with any sensor ,at night everything works ,like mirrors,the lock of the brakes,that anyone knows if any sensor fail what is next,date time (light)not working
Need a little more information on your problem. You have covered BECM faults and Brakes which are different computors and then a burnt light bulbs?
hi.thank you for your reply
daytime(am)to adjust mirrors,wiper fluid,interior lights doesnt work.also to put the car on drive i need to use something to unlock the gear
night time(pm)sometimes works.
pls help
Seems most of your problem is in the daytime AM! Turn headlights on during the daytime and see if they work as at nightime. If everything works, then check headlight switch.
