I just realized that I deleted my trip report while cleaning up my email. I've sent emails to friends requesting a copy. As soon as I get one I will post it.
Sammy, Bring that TR3 to the next club meeting. It's this coming Tues at the Greenbriar resturant in Greenbriar Alabama. I'll buy you a catfish dinner.
DNK, The car was advertised in Hemmings. In the Sept issue I believe.
Matt, go fo it!
Don, you're right it's an adventure
Andy, You're more brave than I.
I hope my trip inspires many of you to take a long trip. When I was younger my '71 TR6 was my primary means of transportation. I can honestly say that it never left me stranded. I always carried a .50 Caliber ammo box with tools and various bits of wire, tape screws...
I regularly drove from my home in southern New Jersey to northern Virginia to visit my parents.
In preparation for this trip I purchased spares for all items I suspected may fail during the trip. The items are listed below.
My original plan was to to a complete servive of the car before departing. However after meeting the owner and staying at his home for the night I felt that he may be insulted thinking that I did not trust his maintenance.
We drove around 500 miles the first day. The next morning we installed new plugs, air filters, thermostat, a Pertronics ignition module and their flame thrower coil. Double checked all fluids and tire pressures. After that we took off for the Oregon coast.
As I mentioned earlier the only problem was a bad rotor. We stopped at a scenic overlook along the California coast for a few quick pictures. I waited in the car with the engine idling. With no warning or fanfare the engine quit. I pumped the lever on the fuel pump to make sure there was fuel and tried to start it. Nothing. We checked one of the plug wires for spark and there was none. However there was spark from the coil to the distributor. My first guess was the ignition module had gone bad. After all it was the most complicated of the new parts we installed the previous morning. We replaced the module with the points and condenser. I forgot to bring feeler gages so we used Dad's shade tree setting for the points gap. "Set the gap to the thickness of a dime". I remember checking this once years ago and finding it a little too wide, so we set the gap by eye to be slightly less than the thickness of a dime. This still did not allow the engine to fire. We replaced the new rotor with the old and it fired off immediately. We left the distributor alone for the rest of the trip.
The area of most concern was the tires. As far as I can tell and to the best of his knowledge these are the original redlines. There is plenty of tread and very little cracking. Ther are quite noisy, but had no problem driving 75+ MPH in several long stints. I'm beginning to look for a spare set of rims to mount some new tires. If I can find a set for a reasonable price I'll save the original wheels and tires for special occasions.
In general I enthusiastically encourage anyone who has dreamt of taking a long trip to do so. Take a look at everything before you leave, carry some spare parts and enjoy the trip. These cars may not be as rock solid reliable as a new Toyota but they are far better than the cars our parents drove. (I'm 53)
Spare Parts ** indicates installation during the trip
Spark Plugs **
Lucas Distributor Cap **
2 Lucas Rotors **
Set of Lucas Points and Condenser
180 Degree Thermostat **
Pertronix Ignitor Ignition Module **
Pertronix Flame Thrower Coil **
3 in One Oil (carb oil) **
Prestone 50/50 Antifreeze (Yellow Jug) **
Redline Water Wetter ** (my only consession to questionable additives)
Mobil 1 15W-50 ** used slightly more than 1 quart. There is an oil leak near the front of the engine. I suspect most of the consumption was due to the leak. I'll know more later.
Marvel Mystery Oil ** 4 oz at each fill-up. This is an old habit for additional lubrication of the top end of the engine.
Fuel Filter
Oil Filter (standard)
Oil FIlter Adapter (screw on)
Screw on Oil Filter (I'll install these after I fix the oil leak and change the oil)
6' of 1/2" Heater Hose
6' of 5/16 Fuel Line
6' of 3/8 Fuel Line
A selection of screw type hose clamps
10' of Bailing Wire
1 Roll of Duct Tape
1 Roll of 3M Rubber Electrical Tape
1 Roll of Regular Electrical tape
2 Carburetor Daiphrams
2 Carb Diaphram Retainer Rings
Upper Radiator Hose ('75 uses a single hose)
Lower Radiator Hoses
Water Pump Belt
Air Pump Belt
Wiper Blades
Fuses
As you can see very few of the spares were used. I also carried my cell phone and a digital camera. I figured the worst that could happen would be that the car broke down and couldn't be repaired on the spot. That would require a little work to arrange temporary storage, a tow and maybe a bus ride home. None of which were intimidating enough to prevent me from taking the trip.
By the way the scenery was outstanding! I can already imagine another visit to the NW just to take a more thorough look at the incredible landscape.
BOBH
