's in thereslave cylinder
Top bolt takes some thought,not sure if Bugeye has a inspection/access on the passenger side of trans housing or not.
Bigest trick is cuting the top ear of slave cylinder so top bolt is not completly removed for removal of slave cylinder, and installing a rubber line helps.
I also understand you can rebuild them in place
Not that hard to remove pedal box and all. I think your torturing yourself to do it any other way.
That is if I understand what your after.
Kurt.
Once again, my head is'nt connected to my mouth!! Musta been late. Slave is a PITA. I agree with mighty midget.
Kurt.
Slave is not difficult really.
Work from under the car.
Much easier to just replace with a new unite.
