Nunyas
I changed out my EGR valve and gulp valve this weekend, and developed a mysterious vacuum leak somewhere. I tried to find it by spraying some WD40 in the surface mating areas of the parts that I changed but that had no effect on the idle. I have to run with the choke partially pulled to keep the idle even.
When I changed my EGR valve, I used the gasket that came with it. I did not use any gasket sealing goop when I put it on though. Should I have used gasket goop there?
Is WD40 too "heavy" to use as a vacuum leak finder? The last time I searched for vacuum leaks I used carburetor cleaner, and instantly found the source of my uneven idle.
I also installed the last piece of heatshield I was missing onto my car. It required me to remove the nut between the front exhaust port and front intake port. I didn't have to remove the manifold just the one nut. I'm pretty sure I got it back on tight enough...
I thought I'd have a much better running car after changing and installing these parts, but it seems it had the opposite effect. Should I go back and check for leaks again using carb cleaner?
