Guinn
I like my Weber DCV carb BUT it does want to run on after the ignition is killed. I have a Run On Control valve inside the right fender which has all the wires and tubes except for the tube that would connect to the Zenith-Stromberg if it were installed. Can anyone tell me (pictures, please) how to make this ROC work?
Also, where is the oil pressure switch and what does it look like? My info is that it is on the firewall but I cannot locate it. This is a part of the ROC system.
Feeling dumber than usual,
Guinn /ubbthreads/images/graemlins/confused.gif
