Cheapsnake
I'm about to do some headwork on my TR8 (Rover 3.5) and prior to pulling the heads I checked compression on each cylinder and got dry readings ranging from 119 to 123, except for a 108, on a cylinder that I know has a bad valve seat. Just for kicks, I squirt oil in the cylinders and ran the check again. I was a bit surprised to get readings 10-15 psi higher. The cylinder walls aren't scored or scuffed and the engine seems to run strong so I'm not sure if I'm looking at bad rings or not. BTW, there's only about 6k on a rebuild.
Are these typical numbers for a 3.5, especially the substantial increase with oil? Thanks a bunch!
Tom
Tom
