AndrewMawson
Out for a spin with my daughter (honest!) nasty noise like a crackling EHT lead - engine dies. Coast to side of road - leads ok but lifting the distributor cap find the brass bit of the rotor arm lying loose on the points and fine brass dust on the base plate. Clean it all up, fit the spare (previously put there having read about them failing by tracking here on the list).
This is a 'rebuilt' distributor that's done less than 100 miles from a reputable UK dealer - the rotor is an aftermarket one and may well be the sole cause of the problem but when I check the play on the driving spindle at the cam there is descernable movement - could it have wobbled enough for physical contact between the rotor and the terminals to knock the brass bit off - maybe though I understand that there is 33 thou clearance.
One puzzle - the brass rotor rivet has completely vanished - gone - vamoosed.
How much shaft play is acceptable ?
