I'm in the process of doing work on the internal workings of my doors, door latches, roll up mechanisms and vent windows. As I was reading in preparation for this effort I saw that it was recommended that if you're going to go inside the door to this extent it would be a good time to repalce the plastic window slides. I purchased the slides and now am having trouble figuring out how to get them installed. I have the door fully uncovered, trim and weatherstrip material removed, and the vent window structure/frame all unscrewed and loose.
Do I have to remove the entire roll up window along with the vent window frame? If so how much of the window and its tracks have to come out? Can anyone give me a simple procedure for repalcing the small six plastic window slides? And then I can get back to replacing the vent window rubber which was the purpose for opening the doors up in the first place. Oh yes, and where are the problem pitfalls if any?
Thanks.
Thanks.
Hi Guest!
