To be effective, a roll bar must be properly installed, with both diagonal and fore and aft bracing. On a unibody, it should be welded to some vertical member of the body, and the floor attachments should be adequately reinforced with backing plates top and bottom.
The commonly seen "style bars" can actually fold in a roll over, and more than likely will. I had a friend killed when she flipped her Jeep equipped with one of these, and it acted like a mouse trap on her neck.
If you want to install one, fine, that's up to you. BUT, just remember, it's there for cosmetics only, and don't let it lull you into a false sense of security.
Jeff
