I have the rebuilt engine installed in the BJ7 ready to fire-up, when I discover that the threads that hold the banjo bolt in the center rocker pedestal are stripped. Can a heli coil be used to cure this problem, or must I purchase a new pedestal? Anyone out there have a good serviceable pedestal that has good banjo bolt threads?
Next question: There seens to be very little clearance between the crankshaft pully and the frame crossmember, perhaps .25-.35 inches. Is this normal? Do I need to place shims under the motor mounts?
Thanks,
Ray
Thanks,
Ray
Hi Guest!
