Rocker oil feed lines
Hello
The shop that rebuilt my engine said tha there is
no problem with the oil gallery in the the rocker
shaft if it is clean and all the extra oil beeing feed to it is not going to do any good if it can not get to through the dirt so first i think you should clean the whole rocker shaft and see if
it helps the problem.
P.s. I went the expensive route with the oil feed
line and then rolling rockers so if you still want to go that way E-mail me
kurt
I put the line on my TR3 along with the aluminum rocker spacers. It quieted my valvetrain down considerably, but at a long traffic light, or other extended idle, the car would load up from the oil getting past the valves. Had to rev the engine occasionally to keep it clear or it would misfire when I took off.
I later installed a NOS Lucas electronic ignition update kit with a different coil and a trigger box on the fender. (Can't remember what they called it) Still uses the points, but reduces the voltage through them. Spark gap got increased to .045", and now it can idle all day with no fouling.
