Thanks Charley I woke up thinking about asking others about the size of the rocker at the top from outside to outside. I was slow to post my rocker problem in the first place because I was pretty sure I had something wrong and could not see it, and I still do. My new rockers measure 2- Âľ.
I also replaced the inner sills and floors. I purchased the sills and floors from VB, they had a nice sale, and the rockers I got from Moss. Anyways when I cut the sill free from the A post, I did not notice the A post was inset into the sill that would be a healthy 1/16. However, moving the A post in makes things worse. So, it was right at the top of the sill where there was notch to let in the A post? Did the notch cut into both folds of sheet metal on the top or just one? When I look at John’s picture again, I can see that the A post is maybe in farther to the first fold of sheet metal. I wish my sills would have been notched it sure would have made things easier to help see the door opening.
I have not welded anything for fear of the obvious, like the doors will not fit. I did get the doors and fenders on with the door working fine by using self-tapping screws. The first problem I saw was the fenders would not come in at the bottom and there was a ÂĽ inch ledge along the top of the rocker.
When I talked to TRF, I only talked about the notch for the A post. I neglected to ask the total width. Now that I see things better I will call them again. They probably miss me. I see Moss has a caveat with the rockers. The caution sounds like length and not width. This car is a 1958 and early 60 K car and I wonder if that makes a difference?
