I am having some engine work done on my 1275 motor. When the mechanic pulled the tranny apart from the engine he found the pressure plate fingers to be badly worn. There is only about 4,000 miles on the car since the 5 speed conversion with the correct Datsun transmission. He said the bearing is good as well as the disk. Has anyone seen this problem or have any ideas why the pressure plate would be showing wear? The car drove fine with the only hitch being that the clutch pedal had to be pushed all the way to the floor to shift. I tried to adjust the Rivergate slave cylinder to help give me some more pedal, but the adjustment was very fine and had to be that way. The clutch master cylinder is the newer one with the plastic tank on it. That push rod is not adjustable.
Thanks,
Charlie
Thanks,
Charlie
Hi Guest!
