jhorton3
Hello Everyone!
It's been a very long time since I've posted. I've got the Rivergate conversion along with their clutch slave cylinder installed. I'm having a lot of grinding into 2nd & 3rd gears, and what I would consider clutch shudder. I can sit with the clutch pedal pressed fully in sitting still and in 1st gear at idle I get what feels like slight bucking, like power is still being delivered to the transmission.
The clutch pedal has a good bit of travel and is solid feeling, not mushy. Plenty of fluid in the hydraulic system, and no leaks.
Is this something I can adjust out with the slave cylinder push rod, or am I facing pulling the engine/transmission for a more serious look/repair?
Hi Guest!
