Calling all mathematicians and engineers ...
If I take my handy micrometer and measure the distance of my ring gear teeth (top of tooth to top of next tooth) I get .410 inch.
If I measure the same "gap" on my starter pinion gear teeth I get .520 inch.
Is that telling me the two don't match and thus don't mesh properly? Or is that not a problem?
I'm just imagining here - but if the teeth don't "match", then eventually the head of one ring gear tooth will crash down on the *head* of one pinion gear tooth, right?
And thus put a *lot* of radial pressure on the pinion gear shaft? Remember, the original starter had been welded so there was no rubber cushioning around that shaft.
And thus put so much pressure on the pinion bearing that the hood will crack and/or snap off?
I would have thought the tooth spacing on both pinion gear and ring gear should be exactly the same.
Thanks.
Tom
Thanks.
Tom
Hi Guest!
