jjbunn
I'm coming back to a problem I shelved a couple of months ago, due to lack of inspiration: the reverse lights on Harold do not light up.
I've checked the bulbs and the bulb connectors, and they're fine.
Under what conditions should the reverse lights come on? When the ignition is on, and reverse gear is engaged? Or does the engine have to be running?(!)
The reverse light switch that is mounted on the transmission in the transmission tunnel: does that ever fail?
What's a good plan of attack to solve this mystery?
Thanks!
Thanks!
