Well, I won't argue with using the professionals, but I just did mine four months ago, and did it myself (and iwth my son-in-law) for two reasons: I wanted to, and the car was still inoperable with parts around my garage.
Here's my experience, and what I did:
Leave the windshield frame on the car of course. Keep the finisher off the gasket, and install that last and only last.
Soap up the gasket and fit it carefully around the glass. Soap it well. Then lift the windshield and gasket as a unit, pushing it in place from the front, of course, and "pulling" from inside the car.
That all sounds fairly easy, but it's not.
Take your shirt off, and get a huge bottle of water so you can replenish yourself as bullets of sweat pour off while you fit, push, adjust and refit the window and gasket. It will pop back out once or twice; it just will.
Since you're not an expert, I strongly recommend two people. One to watch the fit and help push and adjust, and another to sit inside the car and "pull" the gasket lip around the frame.
Some people recommend tools, screwdrivers, and bent hacksaw blades. I'd use my bare hands, and warm soap and water, and strongly recommend no tools except dull plastic pieces to help when absolutely necessary.
What I discovered is that patience is everything. Tiny little bits of gasket lip unfolded back over the inside of the frame--1/4 inch every 30 seconds in some cases. Not to be dramatic, but it took a lot of strength in some cases, and that primarily came from my son-in-law who made me look like bad, and kept scoffing at my wiggly, pathetic little self.
At one point I broke down and grabbed a screwdriver, and then managed quickly to nick the rubber. My son-in-law pushed me aside the curled the gasket in place with his bare hands.
When it finally went in, we'd both been at it for about an hour and a half, and did everything but cry along the way. I know others will cringe, and, yes, a professional could've done it much faster, but we've now got the memories. And it looks good.
Good luck.
