Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
You'll still have the worn part (housing, bush, spindle, etc.). If you'r not concerned about originality, why not put a new distributor in? A couple years ago, I fitted a Mallory dual-point, but they too offer an electronic version.
I recently upgraded that with an MSD 6AL-2 ingition control (requiring the use of only a single points set as the trigger). Running Weber 45 DCOEs, this has been a substantial improvement in low-speed drivability!
There sure is a dizzying array of choices these days. :laugh: Flamethrower full dizzy.
Ignitors 1 and 2 (3 might even work for our cars too) 123 ignition
Mallory, both the uni-lite and the dual point.
I have the dual point with an ignitor replacing the points.
Can you still use the cable driven tach with the above mentioned updates?? That is the reason I have shyed away from changing my distributor.
I am currently using the stock drive with pertronic magnetic points. They seem ok but other than not having to adjust them I haven't really noticed any difference from the stock points performance wise.
Bob
