TR4nut
I picked up some new rotors a while back and it looks like I'm about to put them into use.
My existing crusty looking passenger side rotor has been grabbing badly, I measure 0.004-5 runout which is about double the acceptable spec. Bearings feel tight (no play), but when I drive I get a lot of noise I think from the pads moving as there are no rattle clips or anti-squeal shims on at the time.
Anyway, I was thinking to just swap out the rotor set and see how things behave before doing anything more involved. Couple of questions:
1) The rotors as boxed have milled faces, lots of concentric rings on the surface of the rotors from machining. Is this typical, or is it good practice to turn even new rotors for the installation? My thought is not to worry about it, and just check runout after installation
2) Rotor bolts - I was planning on replacing lock washers only, and retorquing. Bad idea?
Thanks,
Randy
Thanks,
Randy
