MGretired
I have been ignoring a slight “pull” to the left while going around right hand curves, convincing myself it was a gust of wind (classic denial!). It took my wife, who also drives the B, to push me into action by complaining “the darn thing’s squirrelly in right hand curves”. Sure enough, the left rear wheel has about 1/16th – 1/8th inch play in & out. I’m assuming it’s the rear bearing as I can also hear a slight noise when I rotate the wheel. The castle nut is tight & the split pin is intact so it isn’t a loose nut. Since the maintenance book makes it seem very straight-forward (usually when I worry!), thought I’d check with the BBS about the procedure.
The following questions about R & R rear bearings:
•Is it as straight-forward as the book would have you believe?
•Can the bearings be cleaned & repacked if they still look good?
•Normal bearing grease?
•Should I do both sides even if the other side seems tight?
Thanks in advance!
Bob Doc
/ubbthreads/images/graemlins/confused.gif
Thanks in advance!
Bob Doc
