Does anyone out there have recent experience with replacement timing sets for a '74 TR6? I don't want the costly vernier type because I don't anticipate opening things up to modify the cam set up. I ordered and received the hardened double sprocket set and was very discouraged by the apparent low quality of the metal work on the gears and do not want to install this set.Also wonder about the advisability of using the chain with the open link in it -has anyone had problems with this item? Certainly hate to get this far along in a complete engine rebuild and then trash it all with a poor quality timing set!I am going with the Goodparts GP2 cam with 9.0-1 compression and the lightweight flywheel if that affects the recommendations.
Thanks
Thanks
