How do you remove the window glass from the doors? I am assuming that the frame around the window glass must come of the door, but I can't figure out how.
Thanks!
Door panels off, lower windows, remove bolts on side of door, remove bolts to wing window, lift frame with wing. Look through door cut-outs to unbolt window and lift out. Careful not to break.
