Removing the horn for rewiring
Penni
Because the wiring to the horns on my TR3A were smoking and horn constantly on, the wires were cut to immediately stop the problem. Now my husband needs to source the problem.
How do we remove the horn at the steering column
It's a standard steering wheel, non adjustable.
Many thanks, Penni
There is a wiring harness that runs down the center of the steering column (and out through a nut on the steering box). You should start by finding the end of it, near the horn on the drivers side and disconnecting the 4 wires from the main harness. Remove the subharness from any clips and lay it out in front of the car.
Then there are three small slotted-head setscrews in the steering wheel hub that have to be backed out by 1/8" or so (or just remove them entirely). Then the entire control head assembly (horn button plus turn signal switch) should pull away from the wheel, pulling the subharness along with it.
Your choice as to whether to pull the wires entirely out of the steering column, so you can carry the control head to a better place to work; or just pull out a foot or two and work sitting in the driver's seat. Fishing the wires back through the column (and stator tube) is not the easiest thing, so I usually just spread a large white towel on my lap and sit in the driver's seat. Of course, if the stator tube is broken (allowing the head to turn), then you'll have to pull the wires out anyway to replace it.
On the back of the control head, you'll see a large round plate (which is the piece that was trapped against the steering wheel by the 3 set screws). The plate has 3 holes. Turn the plate until the holes line up with 3 flat head screws and undo the screws. That will open up the area where the connections are made.
Be careful keeping track of the three taper tip set screws TR3 driver mentioned. I recall that they are hard to come by.
Bob Hustead
PS There is a compression nut on the steering box that seals the grease in the steering box and pinches the end of the stator tube. You should remove it prior to pulling the tube.
Bob
PPS To borrow a line from emily latella, "NEVERMIND" on the scarcity of the screws. Moss has them in ctalogue.
You don't have to remove the comoression nut either. Not my day on this topic.
Bob
Actually you were right, the nut has to come off to remove the stator tube. But if Penni is lucky, she will get by without having to remove the tube.
Note that when you remove the compression nut, the gear oil also starts dripping out (if there is any).
