VelodromeRacer
Ok, Looks like this Friday is the day for me to remove the race 948 engine from the bugeye. I will remove the hood, but is it necessary to remove the radiator? Any other tricks I should be aware of for this? I will be installing a jet coated header then I am having an exhaust fabricated.
Will the header require me to remove the carbs and intake or just loosen them? I seem to remember that the gasket is one for both, which should probably be replaced anyway.
With the new Taylor gearbox, I assume I will need to install the clutch line to it before I install it all back in the car?
