1960AH_Pops
Member
Good day everyone, I am almost finished with the sandblasting of the BT7 chassis. I am almost to the point I will need to prime it, the only issue I am having is trying to remove the seam sealer from the floor pans. The sandblaster isn't removing it and scraping it is about as useful as using my scraper on the concrete. Are there any recommended products to remove this stuff, if no products then what technique did you use when removing it. I tried a few of the paint/adhesive removers with no luck.
Thanks!
Thanks!
Hi Guest!
