sultanoswing
I need to replace the upper/inner rubber seal of the hatch on my 71 GT (requires getting the hatch off).
Problem is, I can't undo the two large screws each side which hold the hatch on. I do have a size 3 Pozidrive impact bit and impact driver, but still can't seem to loosen the suckers.
Am I using the impact driver correctly? In the words Dr. Venkman, "Well I think so."
I've also tried taking the hatch off by removing the 3 bolts each side which attach the hinge itself to the roof - but no go, as I can't quite get the hinge off over the bolts.
Any thoughts? Do I need to take the car to a panel shop for a drill out?
