Patton
I had to pull the radiator in the Healey last week to replace the water pump and thought that I would start working to clean off the years of caked on grease and grime on the engine and the suspension while I had the extra access.
I rolled the car out in the driveway, and liberlly coated everything with degreaser, and very little came off. I recoated it again, let it sit for 15 minutes, then got out my pressure washer, and all I did was get grease splater everywhere. Basically I wasted 2 hours.
I want to address this again before I put the radiator back on. I need to have this car clean enought that I can work on it without getting covered in grease. I am also starting to think I will go ahead and clean VERY good and paint and detail the engine bay as good as I can with the engine in the car.
Any suggestions as to the degreasing part? What do you use?
Patton
Patton
