Larry, changing the rear bush is not that tough, I went with poly and went back to rubber. Didn't like the ride. A good alignment shop can adjust the rear without the GoodParts bracket. It's all in the shims. Richard's bracket is well thought out and works, but why buy something that will be adjusted once and that's it. I had an old pro alignment guy set my rear alignment after changing to comp spring and a complete new rear suspension. "Just set it and forget it". Also, the manuel does indeed show the use of a jack to change out some components on the front end. I, for one, feel that is the closes thing to suicide. The quality spring compressor you have bought (made for the TR) is a must, a snap to use and will prevent what could look like an IED going off in Baghdad. Use the device, change everything in there and move on.
Bill
