Zima, dry ice and a rubber mallet.
Let the dry ice sit there for a minute, remove it, and the stuff should break into chunks when you smack it with the mallet. Remove the chunks before they have a chance to return to their sticky state.
I saw a friends car after he had done it this way, and it appeared to have worked very well.
Jeff
I'll give the carb cleaner a shot as it's a little easier for me to come by than dry ice. Although, the ice is a great idea. In a prior job of mine, I would use liquid nitrogen to separate adhesives from their backing in order to test competitors adhesive products. So, this is the same concept and I'm sure would work great!!
Jack, I believe it was added as sound deadening material. It may have been to dampen out a resonance in the floor pan. I've never really seen a definitive answer to the question, my ideas are merely guesses based on experience.
Most of the material I've dealt with has been much like very "tarry" tar paper.
I think that modern material, such as "DynoMat" is a better alternative.
Jeff
