Bret
[ QUOTE ]
Thanks Bret, I tried to email you but it was kicked back for some reason. I'm in RB. Thanks for the info - have gotten several things concerning the holes in the block - do you know if I have to have BSPP plugs - thats British Standard Pipe Parallel - or can I use the ones you suggested?
Lonnie - I don't think you'd have to have the smog equipment on unless they're going to do a visual inspection - but I have not had a visual done, I usually go to AAA to do my registration.
Drew
[/ QUOTE ]
Drew,
Sorry about the email being kicked back. I currently have the spam settings on High. I’ll email you using your email address in the BFC and put you in my address book.
Regarding the air rail plugs I don’t know for sure but I believe that any 7/16-20 will work. But I’d go with a fine thread rather than a course thread. Likewise I would use a set screw. Length ½ to ¾ will work fine and use some anti seize. If you ain’t sure take the air rail off and bring it with you to the store. Anyway I found a link that mentions the size required.
https://www.custompistols.com/cars/articles/18vbolt.htm
Also a former employer gave me a used company car back in the mid-90s. I took it to the DMV and all they looked at was the vin # number. No under the hood or safety inspection. I did have to have the car smog tested – but other than that the DMV doesn’t seem to do anything but confirm the vin.
Cheers!
Drew
[/ QUOTE ]
Drew,
Cheers!
