Hi all,
I posted this question earlier, but possibly did not explain clearly enough what my intentions were. I am aware that there are now aftermarket kits that convert rear reflectors to lights. The problem is they only pigtail off of the existing circuit such that you end up with extra lights that function exactly like the originals just in a different location. This certainly makes sense from the stand point of more lights (and higher location) = more visible to modern traffic traveling behind. My problem is with the way the original circuit functions. I don't like the fact that the brake lights and turn signals share a single branch circuit. If I understand the circuit, the turn signals over-ride the brakes if both are on at the same time (not safe at all IMHO). What I wanted to do was to move the turn signals from the rear double filament lamp bases in the existing circuit to single filament bulb holders in the reflector holes and then run a new line from the brake switch (bypassing the flasher unit) back to the OEM brake lights. If you are looking at a wiring diagram, it would involve moving the existing White w/Purple and White w/Brown wires from the OEM brake lights to the new reflector lights (LH and RH respectively) and then disconnecting the Green w/Purple wire from the flasher relay and pigtailing off of it with a new wire back to the OEM brake lights.
Has anyone else attempted this type of conversion and if so, will it work the way I have described?
Thanks much,
Cas
Thanks much,
Cas
