Did it. Had my 12G1316 (smog version of the 12G940) reconditioned. Although I wanted to go with Hap (and spoke with him, receiving lots of good advice - but he was backed up a bit), I needed it quick - and a big firm here in Portland turned it around in 2 days! I removed it and took it all part (removing valves/springs/studs) and took it to Bearing Serices which is very close to my home. Next time I use Hap (hoping he's not too backed up).
a) magnifluxed and blasted (clean inside and out)
b) replaced all bronze guides (and seals)
c) installed hardened seats for the intakes (due to some pocketing of those valves)
d) cleaned up the previous added hardened seats for the exhausts(which really weren't done right)
e) installed my relatively new valves and ground in (and my existing springs which were nearly new)
f) skimmed the top of the head a bit
g) removed all brass plugs on the cylinder side and threaded the holes, then installed new ones (the MAIN REASON for the job)
h) skimmed entire head about .005 or was it .007"
i) pressure-tested and painted
j) they installed one of those overheating tab things at one end of the head (opposite the thermostat end).
Here is a before and after of the cylinder side. A few holes have traces of some very limited corrosion. The pink circles are of those brass plugs (a few with holes); you may recall that the one that spans the gasket fire rings of #2 and #3 had recessed and caused a failure.
Obviously, I also took the opportunity to clean the top of the +.020 pistons and tidy up the top of the block (which is smooth and level). Confirmed TDC while it is open.
Planning to put it in my 1275 (er, 1293cc) tomorrow. Proud papa:
Hi Guest!
