jvandyke
My '63 has a custom oak dash. Pretty but it also has a mix of old and new switches and controls and the wiring is highly suspect, everything worked but no lights for fuel gauge or temp/oil (the wood is 1" thick and I think these two have the lights in a ring or something in the back to shine through the blue plastic edge? any pictures of that anywhere?) Anyway I have a new harness from the PO so I launched into dewiring the whole car, putting in the new harness, adding relays for the headlights and probably the horn.
I'm hoping I can rig some lights for those two gauges. Not being able to check temp and oil pressure or fuel after dark is very disturbing, not to mention not having fuses for anything (there's a few in line fuses, at least one for the electric fuel pump).
I do have an old dash blank, I could ditch the whole wood thing.
Guess I'm just venting and trolling for general advice.
I like this car, don't want it to burn to the ground and my headlights were VERY dim, the original dipswitch was replaced by me right when I got it, it was burned up pretty good (relay!).
Pictures of those goofy light rings would be great.
Opinions on keeping or ditching the wood dash.
How risky is unhooking the oil pressure line or water temp line?
