Chet Zerlin
Hello all,
Driving my 100-6 the other day I heard a clunking sound coming from the rear of the car when I applied the brakes. After checking to make sure the wheels were on tight I jacked up the car and removed the left rear wheel. I found there was in/out play on the hub. (see video below)
As you can see everything was dry at this point but when I removed the hub (single screw) and pulled the half shaft out (to check tightness of the hub nut) fluid leaked out however the hub nut was tight and the lock washer was properly seated.
Questions: would the movement/play shown in the video indicate a bad bearing? Bad oil seal? Or is that "normal"?
Any and all suggestions on what this might be and what I should check are greatly appreciated!
Chet
Chet
