Ohiobugeye
I have returned back to Ohio and have started working on the Bugeye again. I have removed the rearend, radius arms,shocks ,etc. When I went to remove the rear springs, I broke the head off one of the bolts that pass thru the front of the spring and atach to the top mounting plate. The spring is now loose, but the top plate is still atached to the spring and won't let the spring slide out of the mounting hole. Any suggestions what my next step will be?
