Complements of the season from north of the 49th. Thank you to all who, from so far away, have helped me with my wrench turning episodes this year. Amazing technology this internet and equally amazing talent on this forum.
With the lousy weather upon us I decided that this was a good time to replace the sagging rear springs on my '73 'B. I have never attempted this before so need a little advice.
First, Haynes suggest that the body be supported at the "side members" I suppose that would mean jack stands just behind the jacking point. Can't see any other substantial support points but didn't think that this was far enough back. Am I correct in this assumption?
Second, I have cracked all of the nuts prior to the spring removal but got hung up trying to undo the shock absorber arm link from its support bracket on the spring.
Unfortunately. the stud that is protruding from the ball on this arm is turning with the nut. Can't see how to stop this rotation so I can get the nut off. Can't get vice grips in there to grab the stud. Is this a case for using a dremmel to cut the nut off. Hate to wreck the arm if I don't have to. Figured that someone out there must have a fix.
Thanks for your efforts on my behalf.
ceedub
ceedub
