rear spring height
rjc157
i have a 3000 bj8 the rear height is very high springs from moss i know this has been discussed many times but is there a way to lower the rear and doeas anyone manufacture softer springs
The best way is too just wait awhhile, as they will sink down on their own.
:iagree:
However, if you saved your old springs you can try replacing the second leaf from the top of your new springs with the one from your old ones.--Fwiw--Keoke
A rearend shop will roll out(height) what you dont want. I had a 1.5 rolled out. took like half a day cost 180( i think).
wish i did gone many years ago
Well take the first lower leaf out of these springs [Keep It :laugh: ] and see how she sits if it sags later on put it back in and you should be OK---Keoke
The cheapest and easiest way to lower the rear is to use some lowering blocks. You may have to buy some longer U bolts if you use thick blocks but they are not expensive (maybe $20 for 4).
I believe Martin Jansen/Jule has rear springs designed to match or improve upon the ride height of the 3000 MKIII. I have no personal experience on this, but others have posted about it.
I too would like to know more about the lowering blocks.
Martin does have the springs. I purchased mine in 2009 for $250. No shipping charges because they came back with my Frame. He can make them for any height you want.
