rear gear numbers
Which numbers are you referring to? There are numbers stamped on a pad on the housing, directly above the brake fitting, that translate into the gear ratio. For instance, the number 9 stamped over 41 indicates a 4.55.
However, this is only true for the gearset that was initially in the housing. My 4.88 is in a housing that originally had a 4.22 in it. The easiest way is to count the teeth on the ring gear, and divide it by the number of teeth on the pinion.
Jeff
Sigh, and when you get em sorted out do as we do with the track car and use a yellow paint marker and write on them what is what and what goes to what track.
thanks could not remember where they were stamped the gear was from an early Spridget gears all look good bearings run smooth which years/cars had what gears do you know?
The stock rear gear until December, 1968 was a 4.22. This changed to a 3.9 until the rubber bumper cars, when it was replaced by a 3.7.
The higher ratios, 4.55, 4.88, and 5.37 were found in other BMC vehicles, such as the Morris Minor, the Austin A35, or the Morris Postal van, to name a few.
Jeff
It is better to go with the stamped numbers or counting cogs, because you never now if a po has changed it.
Pat
On the side of the ring gear you'll find the stamped numbers as well. On the 4.55 I have in my hand is stamped:
ATA 7109 MOWOG 9 41. The 9 41 being the key numbers
For the more common ratios, the numbers would be:
9 38 = 4.22
10 39 = 3.90
11 41 = 3.73
Jeff
